Angle grinder guard tungsten sharpener
by Jamal
(Great White North)
Here's a good tip. Take your angle grinder guard off and drill a hole in it just barely bigger than the biggest tungsten you will sharpen. Put it on the side it needs to be on so you can set your grinder on the table and hold it with the disc up, start it up, and put your tungsten into the hole. Use it as a guide to hold the tungsten. Voila. Sharpener.
