holiday-deals-banner
AC welding for repairs
by Brian
(PA)
Jody,
You have mentioned using AC with Aluminum Bronze Rod for various situations.
If I'm welding cast iron with Al.Br. rod, what tungsten do I use since I'm trying to do it AC?
If I am welding a funky unknown bronze alloy casting and I want to try Aluminum Bronze rod on AC, what tungsten do I use and how do I prep it?
I'm typically set up with 2% thoriated, sharpened to a point. I don't know jack about AC adjustments.
I prefer 2% lanthanated but
2% thoriated will work fine.
taper at first not quite a sharp as you would on steel and it will ball on its own.
if you have an ac balance knob, set it to more penetration....and use a gas lens
