Stick Welding, MIG Welding, and TIG Welding Blog
All the latest welding videos and tips get posted here on this welding blog. That means several posts weekly.
How to Hold a TIG Torch
how-hold-tig-torch-thumb
Video shows how to hold a TIG torch
Continue reading "How to Hold a TIG Torch"
Arc Control Welding Setting explained
arc-control-dig-settings-chart
Arc Control Welding Setting explained in a short concise Video
Continue reading "Arc Control Welding Setting explained"
Stainless TIG Pipe Welding
walking-the-cup-stainlesspipe-thumb
Videos and Settings for Stainless TIG pipe welding
Continue reading "Stainless TIG Pipe Welding"
How to Weld Titanium
titanium-mistakes-yt-thumb
Clear Crisp Arc Shot Videos on How to Weld Titanium
Continue reading "How to Weld Titanium"
How to TIG Weld Steel Tubing
corner-lap-joints-mild-steel-thumb
Videos on how to tig weld steel tubing and more with clear arc shots
Continue reading "How to TIG Weld Steel Tubing"
How to TIG Cast Iron
cast iron vise lug crack
Videos on how to tig cast iron
Continue reading "How to TIG Cast Iron"
Primeweld TIG 225x Settings videos
easy-tig-settings-2
PrimeWeld TIG 225x Settings Videos on how to TIg weld aluminum and steel
Continue reading "Primeweld TIG 225x Settings videos"
TIG Welding Cold Rolled vs 4130
COLDROLLEDBEAD
Videos comparing TIG welding cold rolled Steel to 4130 chromoly
Continue reading "TIG Welding Cold Rolled vs 4130"
TIG Welding 4130
4130 chromoly tubing cluster weld
Arc Shot Video of TIG Welding 4130 coped Tube
Continue reading "TIG Welding 4130"
TIG Welding Carbon Steel and 4130 Chromoly
4130 cluster weld furick 12
Videos on TIG Welding Carbon Steel and 4130 Chromoly
Continue reading "TIG Welding Carbon Steel and 4130 Chromoly"
How to TIG Steel
how-to-tig-steel-tubes
How to TIG steel Videos for Beginners and more
Continue reading "How to TIG Steel"
How to Weld Vertical MIG
Video Shows clear arc shots and plain talk on How to weld Vertical MIG
Continue reading "How to Weld Vertical MIG"
tig welding 4130 preheat
Welderskills Video shows setings for tig welding 4130 with preheat
Continue reading "tig welding 4130 preheat"
TIG Welding Cup Kit
Weldmonger® TIG Welding Cup Kit reviews
Continue reading "TIG Welding Cup Kit"
how to tig weld stainless steel shown in videos
STAINLESS-ROOT-THUMB-FILLET-TIGFINGER-email
Simple videos and explanations on how to tig weld stainless steel
Continue reading "how to tig weld stainless steel shown in videos"
TIG Welding Stainless Steel Pipe
sanitary-stainless-welding-purge-vs-on-purge
The Best Free Videos on tig welding stainless steel pipe
Continue reading "TIG Welding Stainless Steel Pipe"
Tig Inverters that are affordable and good
Videos show 2 Affordable TIG inverters
Continue reading "Tig Inverters that are affordable and good"
Weldmonger stubby Gas Lens Kit
The Weldmonger Stubby Gas Lens Kit is the First upgrade any welder should make
Continue reading "Weldmonger stubby Gas Lens Kit"
TIG Welding Training Exercise for 11 ga carbon steel
outside corner fillet weld
Video shows TIG Welding Training techniques and arc shots for Steel Corner, Lap, and Tee joints
Continue reading "TIG Welding Training Exercise for 11 ga carbon steel"
How to TIG Weld Steel Corner Joints
Video shows How to Tig Weld Steel outside corner joints and a plasma circle cutter
Continue reading "How to TIG Weld Steel Corner Joints"
How to TIG Weld Carbon Steel
3g-test-tig-root
Video shows how to TIG weld carbon steel
Continue reading "How to TIG Weld Carbon Steel"
How to TIG Weld Cold Rolled Steel
Video shows How to TIG Weld Cold Rolled Steel with arc shots and tips
Continue reading "How to TIG Weld Cold Rolled Steel"
TIG Welding Restarts
stubby vs standard
Video Shows method for making smooth TIG welding restarts
Continue reading "TIG Welding Restarts"
How to TIG Stainless Steel
Videos on How to TIG Stainless Steel along with Simple Tips and explanations
Continue reading "How to TIG Stainless Steel"
Carbon Steel TIG welding
how-many-restarts-thumb
Videos show clear arc shots and explanations on carbon steel tig welding
Continue reading "Carbon Steel TIG welding"
Tig Welding Certification Tips Video Shows new Technique
6g-2inch-tig-freehand-tigfinger-thumb
6G Tig Welding Certification Tips - Video Showing root pass technique and fill passes
Continue reading "Tig Welding Certification Tips Video Shows new Technique"
TIG Welding Cast Iron
aluminum bronze filler on crs
Video with down and dirty tips on TIG welding cast iron to 409 stainless tubing
Continue reading "TIG Welding Cast Iron "
Tips for Tig Welding Filler Rod size
fupa 12 shopify
Video shows tips for picking the right size Tig Welding Filler Rod
Continue reading "Tips for Tig Welding Filler Rod size"
3F Lap Joint - TIG Welding 11 ga Carbon Steel
furick 8 pro 3f lap tig finger
Video Shows Arc Shots and Tips for TIG Welding a 3F lap joint on 11ga Carbon Steel
Continue reading "3F Lap Joint - TIG Welding 11 ga Carbon Steel"
TIG Welding Technique - Video of a Weave Cover Pass on 4 inch pipe
The Freehand Weave Tig welding technique onl Pipe
Continue reading "TIG Welding Technique - Video of a Weave Cover Pass on 4 inch pipe "
How to TIG Weld
Down and dirty Tig Welding Tips that make your "how to Tig Weld" Search Totally worth it
Continue reading "How to TIG Weld "
TigFinger 1
tig finger stainless weave
TIG finger heat shield from weldmonger
Continue reading "TigFinger 1"
TIG Welding Outside Corner Joints - Cold rolled Steel
tig welding outside corner crs
Video shows Awesome arc shots of TIG Welding Corner joints
Continue reading "TIG Welding Outside Corner Joints - Cold rolled Steel"
Primeweld TIG Welder 225X
primeweld torch switch
Video Review of PrimeWeld TIG Welder 225X 2t and 4t settings
Continue reading "Primeweld TIG Welder 225X "
A loook at Welding Symbols on a Load Leveler
blueprint reading for welders book cover
Video shows building a load leveler and welding symbols and mistakes
Continue reading "A loook at Welding Symbols on a Load Leveler"
Tig Welding Repairs
crs tig hole repair
Video demonstrates several common tig welding repairs for machine shops
Continue reading "Tig Welding Repairs"
Mild Steel TIG Welding Rods
11ga-cold-rolled-lap-joint-tig
The Main 2 Mild Steel TIG Welding Rods are ER70S-2 and ER70S-6. Which one works best?
Continue reading "Mild Steel TIG Welding Rods"
TIG Welding on Mild Steel
The Best Videos on TIG Welding on mild steel
Continue reading "TIG Welding on Mild Steel"
Simple Settings for TIG Welding Steel
primeweldtig225-simple-tig-settings-knobs
Continue reading "Simple Settings for TIG Welding Steel"
TIG Aluminum Travel Speed
travel-speed-aluminum
Video shows details of TIG aluminum Travel speed and porosity concerns
Continue reading "TIG Aluminum Travel Speed"
AC TIG Welding Aluminum
Continue reading "AC TIG Welding Aluminum"
Tungsten for TIG Welding Aluminum
The 3 best Tungsten for TIg welding aluminum - Change my mind
Continue reading "Tungsten for TIG Welding Aluminum"
How to TIG weld aluminum lap joints
3f-aluminum-lap-thumb
short video shows how to tig weld aluminum lap joints with arc shots and tips
Continue reading "How to TIG weld aluminum lap joints"
Tips for TIG welding Aluminum
tips-for-tig-welding-aluminum1
Video shows 7 tips for TIG welding aluminum
Continue reading "Tips for TIG welding Aluminum"
Tig Welder Settings For Aluminum - Thin, Thick, horizontal, vertical
outside corner gas lens aluminum weld
Better than a weld Calculator...Welderskills Quick Videos Show tig welder settings along for All types of Aluminum welds
Continue reading "Tig Welder Settings For Aluminum - Thin, Thick, horizontal, vertical"
TIG Welding Stainless Pipe
PURGE-WELDING-STAINLESS-SANITARY-THUMB
Video on TIG Welding Stainless Pipe
Continue reading "TIG Welding Stainless Pipe"
How to TIG Stainless Steel with Videos, Settings, and arc shots galore
Continue reading "How to TIG Stainless"
TIG Welding Overhead
tig-welding-overhead-4f-tee-crs-thumb
Video shows how TIG Welding Overhead is just a matter of getting comfortable
Continue reading "TIG Welding Overhead"
Tig Weld using Mulitple Passes
3g-plate-tig-root-hot-tig-finger
Free Video with arc shots showing a multipass Tig Weld on thick stainless steel
Continue reading "Tig Weld using Mulitple Passes"
