TIG WELDING 11GA COLD ROLLED END CAP SQUARE TUBE
WELD PROCESS = TIG, GTAW, GAS TUNGSTEN ARC WELDIN
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = CORNER JOINT
POSITION = 2F
AMPERAGE = 110-120 AMPS CONTROLLED WITH FOOT PEDAL TUNGSTEN = 2% LANTHANATED, 3/32”
FILLER WIRE = 1/16” ER70S6
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
Did you know?...
***Its Easy to sign up
No Ads, No BS style
