METAL TYPE = COLD ROLLED STEEL
THICKNESS = 3/16"
WELD TYPE = FILLET WELD
JOINT TYPE = TEE
POSITION = 2F
AMPERAGE = 100-115 AMPS CONTROLLED WITH FOOT PEDAL
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 3/32” SILICON BRONZE
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .2 SEC
POST FLOW = 7 SEC
TIPS: KEEP A FAIRLY TIGHT ARC AND WATCH TORCH ANGLE
Whether you are a student working on passing a welding test, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
