THICKNESS = 6 inch schedule 80 pipe wall thickness .430"
WELD TYPE = groove
JOINT TYPE = BUTT WELD OPEN ROOT WITH 5/32” GAP AND ZERO LAND
POSITION = ROLLED IN JACK STANDS
AMPERAGE = 80-85 AMPS USING SCRATCH START AND VALVE TORCH
TUNGSTEN = 2% LANTHANATED, 3/32"FILLER WIRE = 1/8”
ER70S2POLARITY = DCEN
GAS FLOW = 20 CFH argon
CUP SIZE = 7
PRE FLOW = VALVE TORCH
POST FLOW = VALVE TORCH
TIPS: EXTEND ELECTRODE ENOUGH TO GET A DECENT ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL.
trail out on thicker part of pipe wall before snapping out to avoid a crater eye. aka fish eye
Snip oxidized tip of filler metal before each restart
