7018 pipe to plate fillet weld
For me, stick welding something that is round becomes much easier if I chuck up the rod at the right angle in the stinger.  This lets me maintain a good angle just by turning my wrist
WMJacket-heavy-leather
METAL TYPE = CARBON STEEL A36
THICKNESS = ONE INCH TO 1/4" WALL PIPE
WELD TYPE = Fillet weld MULTI PASS
JOINT TYPE = TUBE TO PLATE
POSITION = HORIZONTAL ON BENCH
AMPS = 140 AMPS
ELECTRODE = 7018 1/8"" EXCALIBUR
TIPS: SET THE AMPERAGE HOT ENOUGH TO NOT STICK THE ROD WHEN YOU HOLD A TIGHT ARC… THEN HOLD A TIGHT ARC. DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS. USE AMPERAGE DEMONSTRATED TO GET YOU IN THE BALL PARK. TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
