7018 1/8" 3F TEE 120 AMPS
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE
POSITION = 3f vertical uphill
AMPS = 120 AMPS
ELECTRODE = 7018 1/8”EXCALIBUR
ADDITIONAL SETTINGS = ARC FORCE SET TO 3
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
Did you know?..
