105 amps is the minimum amperage I would run for a 1/4" thick fillet tee joint.
Its just enough, but I prefer around 120 -125 amps
Whether you are a student working on passing a welding test, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
METAL TYPE = CARBON STEEL
THICKNESS = 1/4"
WELD TYPE = Fillet weld
JOINT TYPE = TEE
POSITION = 3f vertical uphill
AMPS = 105 AMPS ( 105 IS A FAIRLY LOW AMPERAGE FOR THIS ROD AND WELD JOINT)
ELECTRODE = 7018 1/8”EXCALIBUR
ADDITIONAL SETTINGS = ARC FORCE SET TO 3
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.
ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.TWEAK AMPS FROM THAT POINT AND ADJUST ARC CONTROL TO FIT THE SITUATION
