2 Quick Videos for you if you have a 6g pipe test coming up with 6010 root and 7018 fill and cap...Good Luck Welder!
METAL TYPE = CARBON STEEL 2 INCH SCHED 80 PIPE
THICKNESS = .218" WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION = 6G PIPE TEST uphill
AMPS = 65-70 AMPS
ELECTRODE = 6010 3/32"
TIPS: DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
THICKNESS = .218” WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
AMPS = 80-85 AMPS
ELECTRODE = 7018 3/32"
