6g 6 inch Pipe Carbon steel Tig hot pass welderskills video
Remember that one of the main goals for the hot pass is to not mess up the root.
Even though welders call the pass after the root pass a "hot pass" amperage is not Always hotter than the root...but often times it is.
For a tig hot pass, about 10-20% more amperage is often used for the hot pass...but sometimes the hot pass is done with the same amperage as the root pass.
IF you go too slow or too hot or both, you can melt thru and sometimes that results in something called "suck back".
Suck Back is when you melt all the way thru the root and usually the metal Sucks back to below flush.
And that will usually fail you on a 6g test.
Here are a few tips that can help prevent suck back:
  • Let the root pass cool off for several minutes before welding the hot pass.
  • Extend the tungsten a bit more than than what was used for the root.
  • Move quickly across the middle of the root and pause just long enough on the walls to wet in
  • keep a bit of pressure on the filler rod to feed the puddle just in case
scroll down for settings
Did you know?..
THICKNESS = 6 inch schedule 80 pipe wall thickness .430"
WELD TYPE = groove
JOINT TYPE = BUTT WELD OPEN ROOT WITH 1/8” GAP AND ZERO LAND
LAYWIRE TECHNIQUE USING FORWARD AND BACK MOTION
POSITION =6G
AMPERAGE =  130 AMPS
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW =  MANUAL
POST FLOW =  10
Snip oxidized tip of filler metal before a restart
