6g 2 inch carbon steel pipe Tig hot pass settings welderksills video
scroll down for settings
Did you know?..
THICKNESS = 2 inch schedule 80 pipe wall thickness .220"
WELD TYPE = groove
JOINT TYPE = BUTT WELD
POSITION = 6G pipe OPEN ROOT WITH 1/8” GAP AND ZERO LAND
AMPERAGE = 110-120
FILLER WIRE = 1/8” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = manual  POST FLOW =  10
ADDITIONAL SETTINGS =   TIPS: EXTEND ELECTRODE ENOUGH TO GET A DECENT ANGLE SO THAT WALKING THE CUP OR FREEHAND WELDING BOTH WORK WELL
Snip oxidized tip of filler metal before a restart
tig welding 2 inch pipe 6g
