3 inch stainless weld
how many passes would it take to weld a 3 inch stainless joint back purged and a procedure and how long would it take
for schedule 40 pipe, i generally takes about 4 passes.
root goes in at around 65 75 amps with a 37 degree bevel , feather edge, and tight 1/8 gap.
second pass same heat
bump up maybe 5-10 amps for the rest but let cool for several minutes between passes.
filler rod is 3/32 or 1/8
