Whether you are a student, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
METAL TYPE = CARBON STEEL PIPE 2 INCH SCHED 80
THICKNESS = 1/4” WALL THICKNESS
WELD TYPE = GROOVE
JOINT TYPE = BUTT
POSITION =6G UPHILL
AMPS = 90 AMPS
ELECTRODE = 7018 3/32” LINCOLN EXCALIBUR
TIPS:DIFFERENT MANUFACTURERS ELECTRODES REQUIRE SLIGHTLY DIFFERENT AMPERAGE SETTINGS.ANY SUCCESSFUL DEMONSTRATION DISPLAYING AMPERAGE SHOULD GET YOU IN THE BALL PARK.
