11ga steel 90 amps bead using er70s6 1/16"
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = BEAD ON PLATE
JOINT TYPE =BEAD ON PLATE
POSITION = FLAT
AMPERAGE = MACHINE SET TO 90 AMPS CONTROLLED WITH PEDAL TUNGSTEN = 2% LANTHANATED, 3/32"
FILLER WIRE = 1/16” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE = 8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC TIPS:
KEEP A TIGHT ARC Aim for an arc length that is equal or less than the diameter of your tungsten electrode. Torch angle can be forgiving provided your arc length is tight. Keep the hot tip of the filler wire shielded by the argon envelope from the tig cup
