11GA SQUARE TUBE TO 11GA FLAT BAR
Did you know?...
***Its Easy to sign up
No Ads, No BS style
METAL TYPE = CARBON STEEL
THICKNESS = 11GA
WELD TYPE = Fillet weld
JOINT TYPE = TEE JOINT
POSITION = 2f HORIZONTAL
AMPERAGE = 125 amps
FILLER WIRE = 1/16” ER70S2
GAS FLOW = 20 CFH argon
CUP SIZE =  8
PRE FLOW = .5 SEC
POST FLOW = 7 SEC
TIPS: KEEP A TIGHT ARC
