115 Volt MIG 2F Corner Joint - PrimeWeld MIG180
This video is a "back to basics" video on short circuit mig welding using 115 volt mig welder.
An outside corner joint is very common when making a box, tank, reservoir, etc. ...especially when a press brake is not available.
Here are the settings and details used for this joint.
material - 11ga steel (1/8") thickness
C25 gas at around 20-25 cfh
voltage 18.1
wire feed speed 149 inches per minute
.035" ER70S6 wire
I used a PrimeWeld MIG180 for this video which is a dual voltage mig welder that runs off either 115 volt or 230 volt power.
I had it plugged in to a standard 115 volt outlet on a 20 amp breaker.
I have several videos using this welder with complete settings listed on each page and you can see those here at the main primeweld mig180 page
primeweld mig180
primeweld mig 180 stuff
primeweld mig180
mig-180-primeweld-settings-techniques-2f-3f-thumb
115-volt-mig-1f-flat-corner-thumb
basics-3f-downhill-11ga-mig180-thumb
