This weekly video is about a welding project, a welding table and modular fixturing, along with a few mig welding tips.
Its a quick welding project on fabricating a shop stool with adjustable height seat.
Reason?
it certainly is not to save money. Fabricating a shop stool does not
save much money if you value your time at all... and you can buy a shop
stool for pretty cheap these days.
So why? well I dont have a shop stool that I am happy with.
and ...
I
got an email recently asking about ideas for welding projects.
Projects where you wind up with something useful when your done.
That got me surfing the net, and then I wound on on bar stools, and then shop stools.
Ah hah! Shop Stools. now that is something useful.
So then I started looking around the shop for leftover materials.
the stuff I used looks something like this:
3/16" x 3/4" x 6" flat bar 6 ea
1" threaded rod 18" long
3-one inch nuts
3 pieces of 1/2" pipe cut to 19-1/2"
I intend to use a piece of sheet metal with a lip welded all the way around for the seat....along with some foam for a cushion.
We will see about that. If I get a better idea, I might shift gears.
Also in a week or so, I plan on making a stool out of an old bike frame.
think
about it. there are tons of scrap bikes out there. All with
adjustable height seats.
I think most of them can be cut up and
repurposed into shop stools. I will definitely look for one with a big
seat because I am not sure sitting on a tiny bike seat will help my
welding one bit.
Mig welding settings used.
for the gaps, I used 17 volts and about 225 ipm with .030" diameter er70s6
For the legs I used 18 volts and 250 ipm.
Stronghand Tools
My
BuildPro table makes short work of simple welding projects like this.
But most folks reading this dont have a precision welding table like
mine.
I drew a circle and used the centerpoint on the table to locate the legs and riser piece.
you could do the same thing on any welding table . It just takes longer.
Here is how I would do it on a standard home built welding table
I would make a center punch mark and use that to scribe a circle using either soapstone or scribe.
Then I would tack weld a one inch nut dead center over the center punch.
the
I would screw one of the nuts about 6 inches from one end and then
screw that end of the 18" long threaded rod into the nut that is tacked
on the table and I would use a rubber mallet to tap it around until the
threaded rod was square with the table top.
If it wont stay
square, I would align both nuts and tack weld s piece of angle iron so
that I could clamp and hold the threaded rod plumb.
from there it should go together just like in the video.
See more welding projects
