When you are welding uphill with 7018…or any other rod for that
matter, you typically will use less amperage than you would for flat or
horizontal welds.
So how hot is hot enough? and how hot is too hot?
that's exactly what I am working on today.
I set up a double sided Tee joint for this video so that I could weld 4
joints at 4 different amperage settings to determine the sweet spot
amperage setting for uphill 7018 1/8” (3.2mm) electrodes on 1/4” (6mm)
thick steel.
So here is what I did…
First joint was done
at 100 amps. Then I cooled the metal all the way before increasing
amperage to 110 amps…then I cooled it off again and increased amps to
120.
At 120 amps, I could tell, things were going to get out of
control if I went any hotter, so I cooled the piece and welded the last
joint at 105 amps.
In Stick Welding, there is something called the Clams Acronym that helps to remember the essential things that go into a good weld.
With CLAMS in mind, Here are some observations from this video on vertical uphill welding with 7018 electrodes.
Current
100 amps is about as low as I want to weld with a 1/8” (3.2mm) 7018.
and 120 was pretty close to max amperage for vertical uphill on 1/4” thick steel (6mm) thick
115 amps probably would have been optimum for the machine I was using
Length of Arc
I tried to maintain a very tight arc length. Not forcing it into the puddle, but very tight.
good advice for stick welding is to set the machine hot enough that the rod wont stick when you hold a tight arc…..then hold a tight arc.
this advice works for all positions but for vertical uphill, less amperage is needed than for horizontal or flat.
Angle
I tried to maintain a 90 degree rod angle knowing that I would probably get into a slight push angle…just seems to happen with the helmet drops
Manipulation of the rod
slight manipulation helps me see where I am going but allowing the light to change. A slight manipulation of the electrode can also help to flatten out the face of the weld
Speed of travel
A general rule of thumb in stick welding is to travel slow enough not to leave undercut….and not much slower than that.
Also, when you are using a slight manipulation technique, its important to pause at the edges of the weld to let them fill with weld.
There is another issue not addressed by CLAMS and that is Arc Blow.
Arc blow can be a real problem on small pieces like I was welding in the video.
Generally speaking, welding at the lower range of an electrode helps prevent arc blow and in this video, For example, I didn’t notice much arc blow at the 100 and 110 amp settings using 1/8" 7018. But at 120, I definitely noticed arc blow toward the top of the weld.
Arc blow happens due to magnetic forces setting up in the work piece that affect the way metal droplets deposit across the arc….
So positioning the ground clamp directly to the piece and midway seemed to help.
