Shielded Metal Arc Welding Rods - Types of Welding Rods and where to use them
In this stick welding arc welding video, the amperage used was not exactly optimal.
Did you know?..
There are several hundred videos over at welderskills.com from beginner to advanced... to down and dirty repair videos on farm equipment...to 6G Pipe  certification test videos.
Whether you are a student working on passing a welding test, hobbyist, or a working welder who wants to sharpen up, I want to encourage you to take the free 7 day test drive and get access to all the courses and over 700 videos.
Shielded metal arc welding video using different types of welding rods...
Several people emailed after seeing the last welding video about different types of welding and asked for a breakdown on shielded metal arc...stick welding electrodes and what in the heck those numbers mean printed on the stick rods. …you know, the AWS stick electrode numbering system.
Some of them also asked for an explanation on where to use the different shielded metal arc welding rods also known as stick welding rods.
But If you want to skip all the mumbo jumbo and just want a down and dirty summary on mild steel types of welding rods, then here it is…
As far as mild steel stick welding rods go, there are only a few that are widely used.
Sure there are other stick welding rods like 7016, or 7014 for specialty applications but the most widely used are E6010, E6011, E6013, E7018, and E7024
6010 arc welding rods are most commonly used for welding root passes in pipe and even for the fill passes on pipelines
6011 arc welding rods are the kissing cousin of 6010 and are designed to be used on AC
6013 arc welding rods are the farmers welding rod and the welding rod most people use first when learning to weld
7018 stick welding electrode is used for pipe welding and structural steel welding and a all kinds of repair welding.
7024 stick rod is used to lay down a heap of weld fast...a really hot and big puddle to get things done quick if its flat or horizontal...and run sweet on AC
If you want to know more than the quick down and dirty summary on stick welding electrodes, then read on.
First of all , lets get some terminology straight. In welding, there are lots of different names for the same thing…you know like, heliarc, vs TIG, vs, Tungsten Inert Gas, vs Gas Tungsten Arc Welding…but it’s all the same thing.
It’s the same with stick welding.
I call it stick welding, but a lot of people just call it arc welding. and some call it rod welding.
The proper AWS term is...
Shielded Metal Arc Welding (SMAW)
 or SMAW for short is what the AWS would like us to call it…I wonder how that is working out. In parts of Europe its referred to as MMA or manual metal arc welding. And I am sure they have some slang terms as well.
No matter what you call it, stick welding is a basic old school welding process that has stood the test of time. Its down and dirty…and I like it.
Even though mig and flux core welding are much faster for production welding, they have not replaced stick welding for portability, simplicity, and reliability.
So lets launch into what the numbers mean that are used to identify a stick welding electrode.
Using E6010 for an example..
The E indicates Electrode because remember, some welding rods are not electrodes. Tig welding rods for instance are usually not used as an electrode but are usually labeled with a ER for electrode or rod because they could be used for either…I don’t see it, but that’s the idea.
The 60 in 6010 indicates the tensile strength in psi. so in theory, if you had one square inch of weld metal in a slow straight pull, it wouldn’t fail until you applied 60,000 lbs.
The last 2 digits indicate position and polarity along with what type flux. See the chart below.
Stick Welding Rod Reference
An important tip to remember is that the second to the last digit in E6010 indicates the positions that that rod can be use. A “1” means that it is an all position rod. A “2” means only flat and horizontal..thats why E7024 rods will attack you with molten blobs if you try to use them overhead.
There is way too much information to memorize here. ..Way to complicated to remember all them so here is a chart to come back to.
The good news is that there are only a few commonly used mild steel stick electrodes.
The most commonly used are E6010, E6011, E6013, E7018, and E7024
6010 are most commonly used for welding root passes in pipe and even for the fill passes on pipelines
6011 are the cousin of 6010 and are designed to be used on AC
6013 is the farmers rod and the rod most people use first when learning to weld
7018 is used for pipe welding and structural steel welding
7024 is used to lay down a heap of weld..a really hot and big puddle to get things done quick if its flat or horizontal
E6010 An aggressive, digging rod that is DC only …does not weld on AC and some inverters do not burn this rod well…. This is a digging penetrating rod and is designed for putting the root bead on the inside of a piece of pipe,
E6011 very similar to a E6010 but will run well on AC…This electrode is used for all-position AC welding or for welding on rusty, dirty, less-than-new metal.
E6013 This is an all-position, AC or DCEP electrode used by farmers for years. It makes a smooth bead but does not dig through rust or paint. …for welding clean, new sheet metal.
E7018 Look around at all the tall buildings. E7018 helped build them. A low-hydrogen, usually DC, all-position electrode used when quality is an issue or for hard-to-weld metals. Can also be used with AC
E7024 Typically used to make a large weld with AC or DCEP in plate that is at least ¼" thick, This rod is only for flat and horizontal welding…forget about using it for overhead or vertical up.
Where to use different types of stick welding rods
#1 you are about to take a welding test for a coal fire power plant in Muscle Shoals Alabama. The test is a 6 inch schedule 80 pipe in 6g . The bevel angle is 37.5 degrees, the gap is 1/8” with a 1/8” land, the root pass is uphill 6010 and you are permitted to run a hot pass with 6010 also to burn out any slag or wagon tracks left by the root pass. You set the machine to DCEP at about 85-90 amps.
#2 You get some free heavy duty angle iron that is ½ thick by about 3 inch legs. But it has a light rust coating on it. You want to build a rack to hold lengths of metal like bar stock, angle iron, channel iron and pipe. But all you have is a Lincoln 225 ac buzz box. Get some 5/32 6011 and weld like hell. It will burn right thru the light rust and give you a strong weld that is bigger than you could get with a 1/8” rod.
#3 Your brother in law wants you to help him weld a fender patch in his 92 nissan maxima. You don’t have a 115 volt mig welder but you do have a small stick welding machine. To get him and your wife off your back , order some tiny little 1/16” 6013 stick rods from northern tool and weld his patch downhill.
#4 you need to build a trailer but you don’t have a shop. The welds need to be strong and look good too. You will be welding outside and the wind might be blowing. 7018 is the ticket. In the hands of a good welder, the slag will roll off with no problem, the welds will be strong as well as smooth.
#5 welding the wedge on a log splitter. You need a solid 1 inch leg fillet weld on each side. That’s a lot of passes. Unless…you crank up your Lincoln ac 225 welder to about 165 amps with a 1/8” 7024 rod. 7024 lays down one of the smoothest and biggest beads of any rod....and if done right, the slag peels off like curly fries
exit shielded metal arc welding rods and learn more about stick welding
go to welding tips home page
