Mig Welding Tips and Articles--- some of the best tips I could think of...
a good ground, correct stickout, mig machine settings and a lot more
" Uphill, Downhill, Push or Pull...join the conversation!!"
mig welding tips...tip #1--Its all about the Stickout betwwen arc and tip
mig tip #2--For thin metal
mig tip #3--the right welding wire for the metal welded
mig tip #4--use the right shielding gas
mig tip #5--is E70S6 best?
tip #6--better penetration, oorah!
"Tip recessed like this only work at high amperage spray transfer...on short arc it will cause "Welds that look like Fido's Butt" except on thin sheet metal !.. "
mig welding tip stickout wrong
mig welding tip stickout better
This is better...Contact Tip is slightly protruding...This alone will help your mig welding
tip #7--out of position welding
tip #8--right size contact tip, liner, wire,
tip #9--watch the spatter and the mig liner
tip #10--keep the cable straight
tip #11--use both hands for better mig welds
welding tip #12--wire feeder tension
tip #13--keep your welding wire clean, heres how
tip #14--changing polarity
tip #15--pushing vs pulling
tip #16--the right size weld
tip #17--auto darkening helmet
tip #18--weld uphill when strength is key
welding tip #19--get a better ground clamp
mig tip #20---use the best-cheapest anti spatter spray
What are the Settings for a 115v Mig Welder?
Settings for your 115v mig welder
Either buy a copper ground clamp or make this trick clamp. Cause Damn! your stock mig welding clamp sucks.
A Cheap Trick for a Better Ground clamp
Mig Welding vs Stick Welding...are the old timers right this time?
Mig vs Stick ..You know the answer
Mig Welding Cast iron
Sometimes you can mig weld cast iron
Tips for welding overhead
Tricks for Mig welding overhead
Mig Welding Stainless Steel
mig welding stainless steel
Mig Welding Supplies
You need these basic mig welding supplies..or else how you gonna mig weld?
Mig Welding Technique
the right mig welding technique that makes the difference
Setting the wire feed speed the same on different mig welding machines
Setting the wire feed to inches per minute
Vertical uphill welding technique
A good technique for uphill welding aka vertical uphill welding
Whats the difference in a wire feed welder and a mig welder?
a wire feed welder is a mig welder
exit mig welding articles page mig welding procedures
