All the latest welding videos and tips get posted here on this welding blog. That means several posts weekly.
TIG Finger Reviews
TIG finger Reviews from real welders in the trenches
Continue reading "TIG Finger Reviews"
Carbide Precipitation in Stainless Steel
What Causes Carbide Precipitation in Stainless Steel
Continue reading "Carbide Precipitation in Stainless Steel"
Best Cup for TIG Welding Stainless
What is the best cup for tig welding stainless steel and 4130 chromoly?
Continue reading "Best Cup for TIG Welding Stainless"
TIG welding stainless lap joint
TIG welding stainless lap joint on 1/4" thick 304L
Continue reading "TIG welding stainless lap joint"
Tig Gas Lens Kit
The Best Tig Gas Lens Kit is the one designed for the type of welding you do. We have kits for tig welding aluminum, 4130, and more
Continue reading "Tig Gas Lens Kit"
Best All Around tungsten electrodes
What is the best all around tungsten for tig welding?
Continue reading "Best All Around tungsten electrodes"
TIG Welding Aluminum Settings
Continue reading "TIG Welding Aluminum Settings"
6011 Welding Rods for Fab job
Video about Building a Dolly using 6011 welding rods and a Buzz Box
Continue reading "6011 Welding Rods for Fab job"
best-gas-for-tig-welding-aluminum
Continue reading "best-gas-for-tig-welding-aluminum"
TIG Finger Display Project
This is an Aluminum TIG welding project. A prototype of a POP Display for TIg fingers
Continue reading "TIG Finger Display Project"
Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info
Down and Dirty Welding tips and tricks , No PhD's allowed
Continue reading "Welding Tips and Tricks - TIG, MIG, Stick and a pantload of other info"
6g Tests with 6010 root
Videos to help you pass 6G tests with 6010 root
Continue reading "6g Tests with 6010 root"
Technique for Stainless Root
Video Shows Crisp Arc Shots and Technique for TIG Welding a Stainless Root pass on 3 inh pipe
Continue reading "Technique for Stainless Root "
Jazzy 10 Ceramic Cup
jazzy 10 cup for TIG welding steel tubing when you need a long stickout and great argon coverage
Continue reading "Jazzy 10 Ceramic Cup "
Filler Rod Angle
Video about TIg welding Filler Rod Angle
Continue reading "Filler Rod Angle"
What is the Best Tungsten for Welding Stainless Steel?
Red? Grey? Purple? Blue? What is the best tungsten for welding stainless?
Continue reading "What is the Best Tungsten for Welding Stainless Steel?"
How to TIG Weld Cold Rolled Steel
Video shows How to TIG Weld Cold Rolled Steel with arc shots and tips
Continue reading "How to TIG Weld Cold Rolled Steel"
Primeweld TIG325X Review
Primeweld TIG325x Review Video shows tig welding box cutter blades as well as 1/4" aluminum
Continue reading "Primeweld TIG325X Review"
TIG Welding Overhead
Video shows how TIG Welding Overhead is just a matter of getting comfortable
Continue reading "TIG Welding Overhead"
Rule of 33 TIG for welding pulse settings
What is the rule of 33 for tig welding pulse settings?
Continue reading "Rule of 33 TIG for welding pulse settings"
MIG Welding 11 ga Corner Flat position
video shows settings and techniques for mig welding 11 ga steel corner joint
Continue reading "MIG Welding 11 ga Corner Flat position"
7018 2G Practice Plate - for Welding Students
Video with arc shots of 7018 2G Practice Plate - for Welding Students
Continue reading "7018 2G Practice Plate - for Welding Students"
Stick Welding overhead 4f tee with 7018 1/8"
Old Timer Said it....Must be True! Stick welding overhead 4F tee joint
Continue reading "Stick Welding overhead 4f tee with 7018 1/8""
3G MIG Uphill Short Circuit vs Pulse Spray
video shows 3G MIG Uphill Short Circuit vs Pulse Spray with clear arc shots and simple explanations
Continue reading "3G MIG Uphill Short Circuit vs Pulse Spray"
Aluminum TIG Welding Technique - Brad Goodman
Short video shows a great aluminum tig welding technique
Continue reading "Aluminum TIG Welding Technique - Brad Goodman"
What Tig Welding Rods Do I need to get Started?
Not Quiet Sure Which Tig Welding Rods to buy? - Sit back and take a listen to this...You need some E70s2 - ER309, 4043, and some 309L or some good ole Hast W
Continue reading "What Tig Welding Rods Do I need to get Started?"
Aluminum 5F Weld Test - Tube to Plate TIG welding test
Video shows details and tips for TIG Welding Aluminum 5F Weld Test - Tube to Plate 🔥
Continue reading "Aluminum 5F Weld Test - Tube to Plate TIG welding test "
Overhead MIG Welding with Primeweld mig180
Overhead MIG Welding with Primeweld MIG 180
Continue reading "Overhead MIG Welding with Primeweld mig180"
TIG Brazing Pulse Settings
Video Demonstrates TIG brazing pulse settings using silicon bronze filler
Continue reading "TIG Brazing Pulse Settings"
How to TIG Weld Cold Rolled Steel - Corner and Lap Joints
video shows exactly how to TIG Weld Cold Rolled Steel - Corner and Lap Joints
Continue reading "How to TIG Weld Cold Rolled Steel - Corner and Lap Joints"
Stick Welding Overhead Rooftop Tee joint
Stick welding rooftop overhead stringer 3/32 7018
Continue reading "Stick Welding Overhead Rooftop Tee joint"
Free Hand TIG Overhead Socket Weld
Video shows Free Hand TIG Overhead Socket Weld
Continue reading "Free Hand TIG Overhead Socket Weld"
Turntable TIG welding
Video shows a few tips for turntable tig welding round parts
Continue reading "Turntable TIG welding"
TIG Welding Overhead Tube to Plate
Video demonstrates 2 techniques for tig welding overhead - walking the cup and freehand
Continue reading "TIG Welding Overhead Tube to Plate"
115volt MIG Welder 11GA Outside Corner Joint - 1F Flat MIG180
Video shows details for using a 115volt MIG Welder on 11GA Outside Corner Joints - 1F Flat MIG180
Continue reading "115volt MIG Welder 11GA Outside Corner Joint - 1F Flat MIG180"
TIG Welding 5052 Aluminum
Video showing details and techniques for tig welding 5052 aluminum
Continue reading "TIG Welding 5052 Aluminum"
115v Mig Settings
Continue reading "115v Mig Settings"
Carbon to Stainless Socket Weld
Video shows carbon to stainless socket weld
Continue reading "Carbon to Stainless Socket Weld "
Macro Etch testing Welds
Video Shows simple macro etch testing method for welds
Continue reading "Macro Etch testing Welds"
Stick Welding a 5F Weld test with 3/32" 7018
Video shows stick welding a 5f weld test using 3/32" 7018
Continue reading "Stick Welding a 5F Weld test with 3/32" 7018"
The Affect of Argon on Cleaning Action for TIG welding aluminum
Does argon flow rate affect cleaning action on aluminum tig welding?
Continue reading "The Affect of Argon on Cleaning Action for TIG welding aluminum"
Primeweld mig180 videos
The best primeweld MIG180 videos on the internet hands down!
Continue reading "Primeweld mig180 videos"
115 Volt MIG 2F Corner Joint - PrimeWeld MIG180
Video showing a 115 Volt MIG 2F Corner Joint using a PrimeWeld MIG180
Continue reading "115 Volt MIG 2F Corner Joint - PrimeWeld MIG180"
115 Volt MIG downhill Corner weld settings and techniques
short video on 115 volt mig downhill corner weld
Continue reading "115 Volt MIG downhill Corner weld settings and techniques"
Aerospace Welding Videos
Videos show tips for passing aerospace welding tests
Continue reading "Aerospace Welding Videos"
2G Aerospace Weld Test - practice tips for taking a d17 welding test
Videos and tips for passing a 2G aerospace welding test
Continue reading "2G Aerospace Weld Test - practice tips for taking a d17 welding test"
Cleaning Aluminum for Welding
Video shows methods of cleaning aluminum for welding
Continue reading "Cleaning Aluminum for Welding"
How to TIG weld Titanium
Video Shows basics of how to tig weld titanium
Continue reading "How to TIG weld Titanium"
